Cartes du Ciel Version 4.0 erhältlich
Halb Off Topic Board
PeterK
Beitrag von PeterK »
Hallo Sternenfreunde,
nach langer Zeit wieder mal ein Update bei Cartes du Ciel:
Version 4.0
New functions:
. Set the tool bar button arangement, size and text in Setup / Toolbar editor. Increase default button size.
◾ The tool bar editor allow you to edit the button bar layout. The function is available from the menu Setup / Tool bar editor.
◾ New performance options from menu File/Reset chart and options…
◾ New tool box function you can activate with the keys F1 to F8.
◾ Scripting functions and custom tool box capabilities.
◾ New representation for the Milky Way. This can be activated from the menu Setup / Display / Lines by unchecking “Milky Way - Line mode”.
◾ Updated Solar system information window with more functionallity
◾ Plot images for the main planetary satellites
◾ More color and label options
◾ Update the artificial satellites TLE files automatically.
◾ Option to add a crosshair to the chart center.
◾ Option to add the meridian line with any projection.
◾ Show comet and asteroid hourly motion in the detail window.
◾ Update download URL for asteroids and comets
◾ New observing list Tour function
◾ Add cursor or telescope position to observing list
◾ Add Tcp/Ip connection to the LX200 telescope interface.
◾ Use INDIstarter to manage the INDI server.
◾ New INDI control panel.
Catalog:
◾ OpenNGC replace NGC2000, it is now include with the base version
◾ Use official IAU star name
◾ The following catalog change require to install the new version with 4.0 in the file name from the catalog download section.
◾ New version of GCVS and WDS catalog
◾ New version of PGC/LEDA with 5 million galaxies
◾ Add index to search planetary nebula by name
◾ Add Sh2 and Barnard catalog
◾ Update the pictures using better coordinates from OpenNGC
Corrections:
◾ Performance improvement with image display
◾ Artificial satellites TLE files can use .txt extension.
◾ Move some menu from File to View and Chart.
◾ Now the program scale the window correctly on high resolution screen. You can set the old behavior in Setup/General.
◾ No more store the program data location in the configuration file. If you need a non-standard location use the new command line option ”–datadir=”.
Übrigend gibt es auch bei SkytechX (ein ziemlich ähnliches Programm wie CdC) ein Update = Version 1.05
Link:
http://skytechx.eu/?page=news
LG+CS
Peter
Canon 1000D, HEQ5-PRO
Schwerkraft nein Danke !
Re: Cartes du Ciel Version 4.0 erhältlich
Beitrag von Rev.Antun »
Servus Peter!
Danke sehr für die Information, da weis ich schon was ich heute Abend bei schlechtwetter tun werde :mrgreen:
Leo_T
Beitrag von Leo_T »
Servus Peter,
danke für die Info. Hab soeben beide Anwendungen aktualisiert!
LG und CS
Leo
hallo Peter,
danke für den Hinweis, bei CdC 4 geht der Kartenaufbau beim ziehen deutlich schneller 8)
WNE
Beitrag von WNE »
Hallo Peter,
danke für die Information.
Die Software SkytechX kannte ich bis dato noch nicht.
LG Werner
